So, I had mostly decided that I wanted mono panels, then must have mis read the ones I pulled the trigger on, and ordered poly unintentionally to save a few bucks.
Does it matter?
I bought 2 Renogy 100 W poly panels to put on my TC. I think they were $115 each.
I can send them back and get the monos, but I'd be paying shipping and the extra 20 or so each.
The poly's seem to be a better size, but that hardly makes much difference in my application.
Also is the ten gauge wire they want me to use appropriate?
I have lots of scrap 12-3 extension chord that I like use as one wire. I think this makes it a 4 gauge or smaller, but don't know how to verify what that really translates to. The factory 10 gauge will be easier to plug and play, if they are sufficient.
Does it matter where I place the controller as far as the distance between the roof top panels and the battery?
They will be a pretty straight vertical run from battery to panel. I can put the controller up higher if it matters.
I still need a battery monitor, and possibly a new system of shore power charging.
I am not sure that my '98 vintage Magnatek charger treats my batteries as well as it should.
Batteries waiting to be installed are a pair of 6V T105's. THey'll be going in an underbody box beneath the new flat bed.
Thanks for any insight,
Dave
Does it matter?
Dave
