More ponderings on a truck shell camper. AC in a hi top?
dbhost
So I have been considering a couple of options. I am leaning heavily toward building my own custom topper, so I can build it wider as a camper body that will allow for a short king size mattress above the truck bed rails.
This is not an insurmountable obstacle, but it would be nice to have something I can just bolt on and mod to my needs quickly instead of designing and building from scratch.
I know I can build a platform for my truck using a Leer hi topper, and one of those steel roller bed frames with some pipe segments to suspend it off the floor, and plywood planking, topped by a modded inexpensive (relatively) cut down memory foam mattress. I can insulate what I can with Reflectix and "rat fur" carpeting. The truck bed already has a bedrug installed so there is that.
The big issue though is where and when I intend to travel / camp. It's generally HOT and HUMID. And with 2 adult human bodies in close proximity on the bed, that makes for a sweaty nights sleep.
Much, if not all of my design work centers around getting some sort of real air conditioner in there and working.
The thoughts are...
#1. Smallest roof top RV unit. These are generally speaking HUGE for the application, and of course, the roof on a hi top, unless I go with a contractor cap, isn't flat but slopes quite a bit.
#2. 5K BTU Window unit AC. Easily run with even the smallest generators. But very hard to adapt to the truck bed. I can make an adapter board that goes in place with the tailgate down, but the bed will block all airflow / keeping the cooled air under the bed.
#3 5K BTU Window unit AC with some sort of topper extension that will allow me to drop the tailgate, lift the liftgate, put the extension in place, and put the AC in place toward the back of the tailgate, allowing me room for airflow through the entire camper.
Option #3 seems the most reasonable. There are taigate tent extensions, but no AC port, or I can design / build something maybe using poor mans fiberglass over foam to help with insulation and keep weight down.
I have seen a youtube video with a couple and the specifics are a bit vague right now due to the early hour, but I believe they are in Florida, using a Truck tent on a Dodge / RAM, and they made a PVC pipe support for a platform that simply jams the AC unit against the side screening of the tent. I might be able to rig something to jam the unit against an open window screen, which might be better anyway as it won't hold the output heat under any tarp awning rig I setup off the back of the truck...
So has anyone here bothered to AC the camper shell of a standard bed pickup truck with any success? An 8' bed truck would have been massively easier, but this is what I have...
DetroitDarin
Scratching a 10 year Itch
as an aside - have you thought about a TopperEZLift? Its the route I'm headed with my Tacoma. $2000 - $200 for vet/military if it applies, and it comes with the tent sides/door stuff.
I've often wondered if the smallest RV AC unit I can find would also work on a camper/canopy shell. Have you considered the ZeroBreeze? It's about $1000, but it has generally good reviews - and I suppose a solar generator could power it at least overnight.
dbhost
Honestly, what I think would be "best" doesn't exist. And that would be a 5K BTU ductless mini split.
There was an episode of Trucks! ever so long ago that had something like the Topper EZ Lift, and it featured tip out bunk ends like a pop up camper trailer. And honestly, if I could find one of those. I't totally hop it, because if I recall right, it could be ordered with an AC port....
I don't mind necessarily schlepping a small window unit if the weather requires it, I would prefer to be where the weather doesn't need it. That might end up being the thing long term...
dbhost
I love my topper ez lift with the weekender package. If your just looking for the tailgate extensions. they have the nomad package. that encloses the talegate.View attachment 668161
Those are nice indeed.
I am thinking something a bit more, mmmm secured? Hard sided. And I am probably showing my age here, but I have never liked the look of cab height truck toppers. To each their own, they just aren't my thing...
Something like what this guy did...
Except maybe not so much uh... angular. Not sure I am explaining it right...
Honestly, I could avoid all of this by simply making the bed adjustable, set up camp, and bed goes down toward the bottom of the truck bed. And then a divider wall to hold the AC and give me a door. Sort of like what this guy did but a different interior setup...
The big problem is the queen bed, above the AC if I set up that way.
I have no qualms whatsoever about setting up where venitlation can get to / from the AC unit...
So what I am thinking, and I could VERY EASILY be wrong, but my thoughts are...
Leer 122. Since the 2004-2008 F150 is getting there in age now. used toppers are hitting the market for cheap, and 122s come up from time to time. Oddly enough, typically missing the back glass. I already talked to my local auto glass shop, and used topper + glass replacement + mounting gaskets should come in sub $400.00
I am thinking about something similar to what the guy linked in the first video did, but more uh, knock down. Maybe use thumb screws and nut inserts to assemble panels in the field, and come up with an AC boot / entry passage. A strip of 3/4" pipe insulation should provide a draft gasket at the dropped tailgate.
I just need it out far enough to basically create a wall that the AC sits in, and have the AC supported by the tailgate.
jesus m anderson
