More Power Puller
gorillamel
Dirty Blonde
Courtesy posting for a friend located in Myakka, FL area:
FS: MORE POWER PULLER hand winch. 3 ton capacity. 35' 5/16" Amsteel Blue rope. This is a true winch, not a come along. Same operation as an electric winch, only you supply the power.
Comes with all the parts pictured -- winch with two hooks, snatch block with hook, safety handle and the optional safety handle extension.
This is a cool tool.
The winch is mechanically perfect. It is cosmetically very good, with paint chipped where the pawls drag on the ratchet teeth. The rope is good, with some typical flat spots you always get with synthetic rope when it's wound tight. The safety handles are brand new, never used. The handles are engineered to bend if you exceed the winch capacity (which I did), and once bent, you buy a new handle.
This top of the line More Power Puller lists for $335.95 (including the handle extension). The best price I could Google is $315.
My price: $175 plus UPS shipping (27 lbs. from 34251)
Check it out here:https://www.wyeth-scott.com/index.asp
PM me if interested and I will give you his contact info.
vtlogger
bump for an awesome winch...if I didn't already have one it would be on it's way to me... good luck with it
flipstick
