BIGdaddy
Have you looked at your steering shaft? There is a rubber section, up by the brake booster end, to soak up vibs and they will fail after a while. I have seen it a couple of times now. There is a fail-safe so not to loose all steering but it does slop around quite a bit. If this is it the shaft will need replacing, either mopar or after market will work.
This describes, in someone else's situation, pretty much what is going on in my system, too. About a 1/4 turn of slop, with no movement from the lower steering setup. I understand that the steering can't really "fail", but I'd like a much more pronounced steering response than I currently have.
This is what I'd use, if I read the exploded diagram correctly...: http://www.jeep4x4center.com/product-information.asp?number=4713943
not a bad price, considering what an integral part it is...
