crawler#976
Opted for a very easy mount - all I lost were the two 12V power outlets.
Removed the shifter cover, sawed off a small piece of plastic behind the power outlets, and cut/bent a metal mounting tab.
Mounted the radio to the shifter cover, mounted the mike clip the the dash, and refitted the trim piece where the outlets used to be. Took me about 2 hours total.
Still need to replace a firewall grommet where I ran the power thru the fire wall - the old one disintigrated trying to remove it.
Still not sure what I'm gonna do with the mag mount antenna. May run the cable thru one of the grommets behind the cab, it's going out thru the Xtra cab window right now. Don't like it tho...
Mark
Mark
