Mounting an ARB Awning to a BajaRack Utility (flat) Rack???
RAM5500 CAMPERTHING
OG Portal Member #183
Hey Guys
I have a BajaRack utility rack on my camper shell and just got the ARB 2000 awning.
The mounting system from BajaRack to mount the awning is cheesy at best. I don't see anyway this will hold up on a long washboard road.
Anyone have an ARB awning mounted to the BajaRack UTILITY (flat no sides) rack?
Any advice? Thanks
Here is a pic and you can see the long brackets and how they obviously flex and move
Could weld or bolt a piece of 1/4" plate to the outside of the rack. Depending on how big you make it you can control the height of where the awning sits. I think a solid piece of plate would hold up.
Colonal Angus
Just re-mounted my awning with fourtreks mounts. I can't recommend them enough. I say re-mounted because I used the L brackets for a little while and they sucked. Tried my hardest to figure out a logical and inexpensive way...no dice. Finally ordered the fourtreks and couldn't be happier.
I have an ironman awning and Gobi flat rack.
RAM5500 CAMPERTHING
Thanks. Would rather a clean bolt on option and not weld to a brand new rack. Will see. Thanks
RAM5500 CAMPERTHING
WOW!! Never heard of these before!
Thanks, looked perfect!! Just ordered them!! :)
Clemtiger84
