Mounting Tools on Roof Rack
Ala5ka
VX'er
I just built a roof basket and need a way to mount the axe, Hi-Lift, jerry can, and shovel. Can you guys think of any way to do it? The base is expanded steel and the sides are angle iron. I want it to be able to bolt on or clamp but discourage thieves. Thanks for any info.
theksmith
a friend helped me make this: http://www.offroadpassport.com/forum/showpost.php?p=2303&postcount=111
then secured the same way as i had before:
also there are pre-made things similiar: http://www.warriorproducts.com/Cata...ser/Racks/FJ_Cruiser_Shovel_Axe_Brackets.html
matthewp
Combat Truck Monkey
For my Hi-Lift jack, I use these:[ame="http://www.amazon.com/gp/product/images/B003CEODQI/ref=dp_image_z_0?ie=UTF8&n=15684181&s=automotive"]Amazon.com: Hi-Lift Jack TM-700 1"-2" Adjustable Tube Mount[/ame]
As you can see, it's designed for a tube mount but it can easily just be bolted to your angle iron.
4xCoffee
