Mukiwa Build Thread
Mukiwa
I have a 2003 Nissan Xterra with 150 000kms. It's totally stock and as some of my "truck" friends say it's kinda a soccer mom vehicle... Not that I agree at all. I'm hoping to make it more of an expedition type off road vehicle. Not a jacked up rock crawler, mudding machine with 44" tires but a comfortable for the long haul and very sure-footed on a challenging trail expedition vehicle.
Stage 1
[x] Tires - 31' Kelly Safari TSR (My tires were already ratty so it was a good excuse)
[x] PML
[ ] Bilstines all round
[ ] Paint Rims
[x] Paint Rack
[x] Dephep Rack
[ ] Tire spacers (1.5') or maybe new rims with less backspace ***What would you do?? Advise welcome***
[x] CB with PA system
[ ] Front Lights
[x] Side Lights
[x] Rear Lights
[x] Rear Storage organiser
[ ] Timing Belt
[ ] Resonator Mod
[x] Rear Sway Bar, Mud Flaps, and side step delete
[x] Raised rear diff breather
Stage 2
[ ] Exhaust (Flowmaster super 44)
[ ] Snorkel
[ ] Sliders
[ ] Skid Plates
[ ] Rear Bumper w/ Tire Holder
[ ] 3" Suspension Lift
As it sits now:
Tires - Kelly Safari TSR's great tires!!
I finally got round to instaling my blue sea fuse box and cb radio/pa system today...
The red wires running along the firewall are going to the cb. I'm going to put it all in that black hose stuff when I have all my lights etc wired up.
The wires going throu the grommet... I only had red wire so I wrapped black tape every few inches on the negative wire to destinguish between the two.
My wife drives the X to work most of the time and she didnt want the CB on the dash or anywhere in sight lol this works pretty good thou.
I had it all wired up and when I went to put the fuse in it kept blowing ... uuggg short somwhere... sure enough I had forgoten to tape up a connection and the two wires were touching at the connections. Its all working now thou.
After having piles of junk colecting in the back of the X I decided its time for a rear cargo organizer. I read every post on clubx and other sites like expeditionportal which have lots of info on the topic... Finaly I drew out a plan and went to town.
I dont have any pics of it being built as I was busy building it and forgot to take pics. But I have the finnished product so far.
Bought the Drawer sliders at RONA for $20 bucks a pair
Found some rubber sheeting at work and snuck it out lol
The rubber worked perfectly to stop things from sliding around
Bottom "Tool" Drawer
Handles also from RONA $4
The handle made lots of noise when I was driving so I put some rubber under the bottom screw... I"ll see how that works
Top Drawer with a few parts for mods to come
2 Rubber Maids or a Cooler fit in the open side
Storage for my recovery gear in the space behind the seat... easy access
There are a few more things I will be adding such as some sort of rack or bin on top so I can put stuff on top without them falling off the side. Also planning on putting my inverter on the side and a flashlight mount somewhere. Another thing I thought of after I had already started was sleeping in the X would be kinda hard with a huge box in the back, but I figured if I can take the box our where ever I'm camping and use it as a kitchen area... I was looking at another write up here on club X I think it was KUMA who made something similar with a fold over sleeping area which is another option in the future. But so far it works great and everything is neat and tidy...
On my last camping trip I had a rare lightbulb moment and though of using the box as a kitchen when at a campsite with no picknic table and it worked awsome
I had a small safe kicking around and decided to put it into the back of the box so it is accessed from behind the seat. I bolted it down to the bottom of the box so if someone wants to steal it
they will have to run off with a big wooden box... good luck getting very far lol.
Cutting a hole in the back of the box.
Safe in place bolted down to the bottom of the box.
And finnaly I painted it with bedliner to take away the rough wood look and it looks much better. Im still trying to decide if I should put aluminum edging on it...
I also painted the back of the box and finnished adding all the stuff including a shotgun mount. I wanted a hidden spot with easy access and this works the best.
Note: This pic is from the front seats looking back with the rear seats folded down.
Thats it for now although I still have more plans for it... This is almost a thread within a thread! Inception.
Mukiwa
I picked up some cheap lights at princess auto (2 for $30) and Im working at putting them on the roof rack as side lights right above the front doors...
I got them all wired up with the wires going up the weather stripping for now
A pic with the roof basket back on
I got all the lights wired up and now I wired in three "aircraft" switches, Im panning on adding rear and front lights too..
Another Pic
I used a 30A relay even though I think the switch could have handled the Lights
Across the firewall.. Ill be putting all the wires in that black tube stuff when I'm finnished all the wiring.
Thru the grommet
The wires to the roof go up the weather stripping on the passenger side.. Also temp till I get everything done on the roof... I don't want to drill a hole and a few days later decide I need another wire up there so I'll wire everything like this and then clean it up later.
And there was light!
Ill post some nite pics when I get around to it. But I'm pretty happy at pulling this off as I'm a newb at wiring!
:lutscher-big:
I had nothing to do this afternoon so I decided to wire up a light under my hood as working at night on the side of the road with a flashlight in your mouth sucks!!!
Got a cheap flood style light and wired it up to my fuse box.. works like a charm!
The switch looks kinda ugly but it works. My famous words are `Ill fix it another time`...
I also took off the mud flaps which took all of 5 mins, although I stripped the screws on the rear flaps and ended up cutting them off with my knife... whatever works
Ok here are some pics with the PML completed...
Just finnished blacking out the roof rack rails. I havent done the plastics yet, ran out of paint lol
I took the rails off, sanded sanded sanded till all the chips and peeling paint was smooth then I wiped it down with some soapy water and let them dry. After a few mins I rubbed them down with a dry rag and started spraying primer. I did two coats and let that dry then sprayed a few coats of Rustoleum Flat Black. So far they look pretty good except for a few spots that paper stuck to when I was painting the bottom. :aufkopfhauen-big:
My Hepdep roof rack should be ariving in the next couple weeks... Cant wait!!
Painting...
The X bald
Voila!
Mukiwa
Just finnished painting the wind deflector and stock cargo basket black.. kinda ran out of paint on the basket so I'll have to wait to put that on but here it is so far.
I found an old rabbit cage and ripped it apart and turned it into a lobo rack... here are some pics
I also added some stickers from Creapy and they are awsome!
I blacked out the rear Decal and added the off road and the mountains stickers
I also ordered a Hepdep rack from Hepsdesigns and just got it today.
Mukiwa
I wired up my reverse lights the other night:) Finally!!
I had the iPad out with the Relay Diagram.. It works awsome!
Close Up
Mukiwa
I started working on a first aid / survival kit for the X and this is what I've got so far...\
Its actually one of those wall mounted Industrial First Aid kits and I painted it with BedLiner and threw that sticker on it.
I wanted to put it in the same spot the stock kit is but it didnt fit so I looked around and nothing else seemed to work. I finnaly decided to cut into the X for the first time lol. Its fine once you start but the thought of messing up and the hassle of getting a new rear plastic thing... lame.
Anyways I cut it...
And stuck on some velcro
And here it is so far
Ill try and get it back on the X tomoro if I get the time and snap a finnished product pic..
Xterabl
Hey, very nice build.
Funny thing...I emailed dephep 2X about rack price/shipping for my X...it wasn't clear from their website that they build for 1st gen x's, and got not reply from either one.
I guess they have too much business???
anyways, I'll be now making my own rack...with about the same utility...for <1/2 the price of the (reasonably priced) dephep rack. Really wish they had returned my emails....
Mukiwa
Ya it was a challenge trying to get in contact with them.... they need to work on their customer service. It took about two months till he even started making it and another month till it shipped. It was worth it thou.
Slicky72
Ya forsure.. Im actually in langley. Are you on ClubXterra.org?? I am Mukiwa there also.
I have been on that site before but I found there was too much bickering . Maybe that has changed now but I like this site and there are a ton of great ideas on here.
timh
Very nice build so far. I need to double check my PML in the front. After lifting yours it looks like it sits a bit higher than mine. How much clearence between the topout bumpstop and UCA do you have after the PML?
Mukiwa
Sorry I never replyed to your post! I must not be getting notifyed... I cant remember off hand how much room there was but it says on a few of the PML threads how much you should have and I remember I had the exact amount... Im pretty sure it was 3/4 inch or something but dont quote me on that.
I never really noticed the bickering but I only read the trail reports and about the mines, ghost towns etc in my area. Ive recently joined Overland Canada and there is alot of local stuff there too.
