Multiple Port High Current USB Power Ports
We have all run into situations with not enough USB charging or power ports. Usually they are low current and will not charge newer devices.
This neat little device will give you 4 high current, 3 amp, USB charging ports. It is portable or you could possible find some way of mounting it. I would not recommend leaving it plugged in when not in use, as they is a small amp draw.
https://www.portableuniversalpower.com/usb-multi-tap/
The secret to the whole thing is he has found or is making a stick type board with a 5 volt 3 amp regulator and a USB connector. That is all it is. A little bit of creativity in 3D design and printer and POOF he pops out an inexpensive usable device. Saves me the time and trouble of making my own.
Clemtiger84
