Rockcrawlintoy
I ended up getting an 07 JKU a few years ago with the intention of building a wheeler out of it. My attitude has changed a bit and want to be able to drive it to work, on trips and do the Rubicon trail if I wanted.
Here it is when I got it. It was 100% stock with 100k on it.
First thing I did was put some frame mounted sliders on it. I ended up with the Poison Spyder rocker knockers.
I was used to dual ultimate cases from Marlin Crawler on my one truck (223:1 is hard to give up) so I got a 4:1 t case from a rubicon. I still need to install it.
I also knew the JK front axles are not up to snuff. They have a weak housing and inner knuckles and the HP Dana 30 I have may not like life with the planned 37 inch tires. So I splurged and got a Pro rock 44 from Dynatrac. I also stuffed it with 4.88 gears and an ARB.
Ill post more in a bit.
