Hi, I've been a lurker on here for a while. I thought I'd show you my vehicle build. I hope to either acquire or most likely build a simple light weight pop up for the back. I like light weight , simplicity and reliability, those were my objectives in this build.
The base vehicle is a 1990 F150 4x4 Super Cab that I bought new. I put close to 190k miles on it before deciding to rebuild it. It originally had the 302.
Specs and build details:
* The truck was totally torn down to the point of cutting the frame cross members off the rails,.
* The C section rails were sand blasted and then boxed and plated with 1/8 plate.
* Cross members were sand blasted and then the frame was reassembled.
* The total frame was hot dip galvanized and then shot with epoxy primer and two pack.
* Cummins 3.9 4BT was totally rebuilt including the VE pump. Holset HX25w6 installed for instant boost, boost controlled to 25 psi. KDP fix. piston lift pump with regulated return to give 10 psi into the VE.
Original hydraulic engine mounts used on fabbed brackets. Dodge IC installed. VE pump turned up, I estimate 175 hp. The electric fuel solenoid shut off is gutted so the engine is shut down with the mechanical shut off on the VE pump from inside the cab
* Original M5R2 5 spd and 1356 TC were rebuilt and used.
* Gear Vendors OD installed giving 8 forward ratios. In reality I don't split 2nd so actually use 7. 1,2,3,3 over,4,5 and 5 over. 5th over gives 1650 rpm at 75 mph.
* Dana 44 solid front axle sourced, rebuilt and installed, 3.5 gears with Eaton Tru-Trac LSD. Moved forward 3/4" to clear front cross member. Fabbed tie rods, track arm and trailing arms. HD coils with Bilstein 5100 shocks. Warn hubs.
* Ford 9" rear sourced and rebuilt, 3.50 gears with Eaton Tru-trac LSD, original leafs with Firestone bags, Bilstein shocks. Explorer discs installed.
* The cab was gutted, floor repaired, door lowers and cab corners replaced. Explorer power seats and console installed.
* Front clip from a 93 was installed along with the windows in the cab extension.
* Fabbed custom aluminum flatbed along with aluminum front and rear bumpers and cab steps. The bed sides are removable. Custom storage boxes.
* Toyo 285/75R16 AT's on ProComp alloys.
* Total fuel capacity 34 gals. The rear tank contents are transferred to the front tank as needed with the stock rear in-tank fuel pump. 4BT lift pump draws from front tank.
I've put about 20k on it since the build, a blast to drive and gets 23 mpg cruising at 75. I did everything except install the new windshield,![IMG-1423 (1).JPG IMG-1423 (1).JPG](https://expeditionportal.com/forum/data/attachments/581/581572-dc792210e9535af7a24a4eb6bfa7921c.jpg)
