Alabama4WD
Earlier this year I purchased my first truck! A 1998 Mitsu. Montero/Pajero with 176k. This truck is amazing! I mean. Dang. Our relationship was spectacular until about three weeks ago when I decided it was time to change the spark plugs and rocker cover gaskets. I had taken the diagrams from the shop service manuals and started taking everything off. The air intake manifold was a real "women" to take off. After several days of tinkering and documenting which part went where, I gained access to the actual block. Things went downhill from here.
I tried to take the covers off, but they kept hitting some other engine component. I did manage to gain just enough space to put in new spark plug seals. I looked for old valve gaskets and DID NOT SEE ANY?! Still frustrated I couldn't remove them, I gave up and reassembled it with new plugs and wires. I said to myself that I'd save that task for a mechanic. So it worked when I turned it over. Forgot to mention that I also replaced every gasket I had access to, just not the cover gaskets.
Fast forward to NOW. I just recently installed a CB radio and it will receive but won't transmit. I CAN fix that. So i decided while I'm at it to replace the front door speakers with some 6.5" 250w BOSS chaos speakers and install a new receiver. HERE IS THE PROBLEM: So the genius mitsubishi engineers decided that this truck needed a total of six speakers. No big deal you say? Well apparently there is a factory amp to power the speakers if you got the Infinity package which is what I unknowingly bought. When I took the driver's door apart to replace the speaker, the window crapped out. The speaker was also not loud at all. Very soft sound. Replacing the receiver was a killer as well. You have to have an amp hook up in the aftermarket receiver which I didn't know. Maybe the 250w is too much for the current stock system? I LOVE this truck, but it has only been a pain in the ***** and wallet. I'm sitting here out of all mechanical confidence. Any advice for a stereo replacement or anything else? Do you want me to keep ya'll updated? Let me know PLEASE!!!
P.S. It's coming up on 180k. So I'm saving for a timing belt and water pump change on top of new tires.
