My budget expedition trailer build: wood exterior, swing out kitchenette, and more .
bybeed1
Hey guys,
Been lurking here for quite some time! New to this forum, but been a part of other forums for 15+ years. I want to thank everyone here for showing their builds, I have had so much inspiration from all of you!
Here are the goals for my trailer:
1. Budget Build!
2. Simple as possible
3. Rugged, durable, easy to work on
4. Functional
So far I am less than $250 into my build. I have been very fortunate and lucky at time to pick up many of my items for free and/or very cheap!
Trailer: I got it for free from my dad. It was in pretty rough shape, but a great starting point!
I got an extra piece of T1-11 plywood from my family cabin that I am going to use as the bottom board for the trailer
Replaced the main center beam... it was completely rotted out! I also traded a small air compressor for a new axle, and was able to salvage the same leaf springs from the old axle.
I completely lucked out and picked up a set of limited tundra/sequoia wheels for FREE! I will be running these wheels on my trailer and my 3rd gen 4Runner.
Started building my vertical supports and corners. (Dont mind the mannequin in the background... its for my business!
Test fitting bottom plywood, cooler, and 2x6's
Exterior 2x6's initial fitment and measurements
Tailgate, Kitchenette framing, and 2x6's bolted
I hated the look of the round tubing as my "vertical posts" on the sides of the trailer, so I cut them off went with some flat bar instead!
As of yesterday (2/2/16), I have tied everything together on the main frame, finished the tailgate latches, capped the top, and bought my 23/32 sheet of plywood for my lid (not pictured).
Sitting next to my 4Runner... makes my runner look tiny! Guess its time to install that 3" lift that's been sitting in my garage for 3 months, and pick up some 33's!
I still have a **** ton to do, but it should be "functional" as a box very soon! I need to build my multi link hitch system, build some fenders, install my lights, and mount my lid to make it usable.
I have really big plans for this trailer that will "eventually" include:
3-4 man RTT on pop up frame (like BoxRocket's) to allow access to lid
Full kitchenette with running water, and Ecotemp L5 heater
Electrical system including 12V/110 power, large inverter, LED lighting, Solar Power charging capabilites
On board air compressor
Rear tire swing out carrier
Fender "extensions" all around to hold propane, jerry cans, water cans etc,
Lot's more that I know I'm forgetting right now.
Let me know what you think, thanks for taking a look!
bybeed1
Update: getting closer! Lid installed and fenders outlined! Multi-Axis Hitch is next, followed by tail lights, skinning the fenders, and rear tire carrier!
M35A2
Tinkerer
Really nice craftsmanship; congratulations!
It would be some work, but if you remove the 2x6's and dado a groove along each edge, say 1/2", you can run narrow strips of plywood in between. This will keep things watertight as the 2x6's expand and shrink over time.
bybeed1
Thanks man! I really appreciate it...
I was thinking of doing something like that! Thank you for the reassurance and details how the best way to do it :)
