My mobile HF station
gary in ohio
Not quite an expo rig, but my daily driver. 2002 Avalanche with an Icom 706MKGII. Antennas right now is a single 80m hamstick, I have a 12ft whip and tuner that will go on it soon.
gary in ohio
Looks Good, how did you mount the faceplate?
The faceplate is mounted into an overhead cubby using some wood molding I had. The attached photo shows the head mount and wood blocking. On the right side of the mount I use a couple of bolts to hold the right side out a bit and gives the head a slant to the driver side. When the face plate is mounted you really cant even see the wood unless you really look for it.
gary in ohio
I'm curious about the antenna mount. Is that an NMO to 3/8-24 adapter?
The antenna mount is a Breedlove Jerry makes some fantastic antenna mounts. On the top side its a standard 3/8-24 for an antenna and unlike a lot of mounts who use the same size hold on the bottom this one has 1/2-24 bolt and that bolt has a 3/16 inch screw in it for connection to a coax/feed cable. The insulator is heavy duty milled Delerin. The breedlove mount sets on a stainless steel plate and that is connected to a steal L bracket that matches up with the factory holes where the plastic handhold was mounted.
the pix show the l bracket, the plate and the completed unit before mounting.
cletaco
Thanks for the info. Looks very stout!
gary in ohio
Very Nice. Where did you find a 12' whip?
The whip is actually a 16ft commercial whip made by ITT industry. Picked it up at the Dayton Hamventon a few years ago, Wish I had several more. Its a nice high quality whip. The whip is consist of four 4ft sections. 3 of the sections use a standard 3/8-24 threads and the top section is smaller, So I can set it up as an 8ft whip, 12ft whip or 16ft whip and use the same base mount. I typically run 3 sections for a 12ft whip fed through an SGG wire tuner. If I am at a fixed location for a while I can put the last 4ft section on. The 16ft even tied down is a bit big to manager on a moving vehicle. The 12ft isnt bad.
A pix of my old tahoe with the whip can be seen here along with an older pix of my blazer with a husler antenna system.
Goldenbora
