mkitchen
My set up for the dutch ovens is ever changing (and I hope improving). After using an MSR backpacking stove for many, many years, I have grown to value the light weight aluminum heat shield that came with it. That little bit of foil did wonders in directing the heat to the pot above. So if the concept works good for MSR it should do well for a dutch oven as well.
I originally just used the dutch oven with wood coals that were shoveled off to the side of the fire. I then moved up to using briquettes. This was an improvement but the briquettes would cook down into the dirt. I have seen some pretty neat stands that folks use but I wanted to keep my outfit small and simple. Hence the idea of using a cheap pizza cooking pan to hold the briquettes. My first step proved to be an improvement and still be easlily transportable.
My new step forward is developing a simple heat shield that works like the MSR heat shield. It had to be something portable, cheap and functional. So the idea of hinged licence plates came about. I'm sure this is not a new idea but it is new to me. All of my DO gear still fits in a box.
Here is a shot of 10 license plates hooked together with hog rings and folded up.
Here is a shot of my 10" oven with the pizza pan sheet under it. This pan works great and my 12" fits on it fine.
And here is a shot of the whole outfit.
Now I need to get out and give it all a try. I thought about heading out to camp this weekend but the temps are dropping down to the the low 20's over the weekend. In fact it started sleeting out as I was finishing up the heat shield and adjusting the spot lights on the Tacoma. My hands are still cold.
Mikey
Mikey
