My new Skamper 100s
Blackfeather
Well i just purchased my first camper a Skamper 100s i could not pass up the deal for 200$!! Its solid and the interior and canvas are in extreamly good shape . Have no idea what year it is but it does need a new lift system if i can find one and i have to re attach the lift pole on the left rear corner. Then ill see how the electric is later . my big fear is i have to replace the i side ofthe roof never did it before is it hard to do ? And ill need to remove thecanvas to fix the pole i know its got some over hang on my 2500 but with tailgate down im at 8.5' and the truck never knew it was there for the 4hr ride home 522527522529522528522530522531
My best guess is the roof framing is rotted in the corners and you will have to replace the framing. Most of the campers that use that lift system end up that way if not taken care. I wouldn't try a quick fix patch job. You may as well pull the roof, flip in over and fix it right. With a little searching I'm sure you can threads where folks have done this repair and it will walk you right through the job.
Blackfeather
Thanks yea thats the plan im gona do it right take my time so i can really enjoy it when its done
andytruck
I clicked to see if it was my old one. Sorry to hear of your purchase. Good luck, lol.
I did extensive roof/lift repair and never got it quite right. There are lots of pics of it , some here skamper
The Heco lift system is awful. It has torsion bars inside the poles that run along the top. These "sag" over time and need to be clocked if the roof is not neutrally bouyant [sp]. It is a six sided clock inside, so is big twist if you do and huge section of canvas will need to come out.
Yours looks pretty straight, but mine skewed off to the left when raised. I never figured that out or got it fixed.
The Heco crank is made of pot metal and is good for 30-40 lifts then is ruined, unless your roof torsion bars are doing their job. Mine took a lot of force to raise.
The wood rots where the torsion bars are bolted in, and I can see yours have issues and seem to have twisted. The tension will arch the rear of the roof up. It should be flat, but the aluminum trim will bow up in the middle. This is from the constant tension. Eventually the wood gives way and mounts twist, faster if there is rot.
Best solution is to throw existing roof in trash and make your own, very light, roof and use accordian [ok, spell checker not working today] braces and gas shocks to hold up the light roof, this would lower your overall profile also. Sounds hard? Fixing that Heco roof is harder.
One cool thing I did was to raise the sink/stove counter top. This gave me more storage under the counter and since I did not cook with lid closed gave me a more normal height counter.
I sold it bc I hated the issues with the Heco lift and all I ever saw was all the work I put into it that I never really was able to finish or get right.
I have more pics of the actual renovation (not the mandatory repairs) somewhere.
Houie
