My Omani Nissan Patrol intro
UK4X4
Well I'm two weeks into owning this benemoth on wheels, and still like it !
4.8 ltr with 280 horsies under the hood and 425 nm of torq at 3500rpm
Manual
Factory roll cage
95 ltr main tank and a 40 ltr sub tank with electric switch
Light guards front and rear
I painted the rears already- the fronts to change to black too and probably the rims as well
I put on my 285 75R16's KM2's and they don't even look big
as a note these are the same size as 33's on my old disco that required a 4" lift to clear them
The vehicle comes with a pintle hitch- labled do not use for towing....straight pull only for recovery.
So it can take a straight pull of 2500kg but can't tow a trailer ?......
well my little camping one should be OK
So I fabbed up a mount for a lock and roll and wired a 7 pin plug for the trailer lights
changed the fan clutch......insurance as the spring on the front was rusty
serviced the engine........
The oil filter on this thing is just a tad bigger than a can of red bull--------I thought the parts guy had made a mistake when i picked it up.
Seemingly Nissan don't think there's much to filter out------the air filter on the other hand is the size of a bucket.
Wired a 3 way 12 volt receptical in the rear for the fridge, through the chassis the whole way- no C channel on this baby
Greased me UJ's, changed my fuel filter
soon to be added
Storage drawers
gear guard between boot and passengers
fridge
rack for mounting sand ladders
winch-----surprisingly Nissan can supply a warn winch mount which sits behind the standard bumper, you just notch out a hole for the fairlead..
here's a few pics !
UK4X4
"the "wrong" side "
yes I know I keep trying to change gear with the door handle :)
Do's yours have the same labling for the factory 4 bolt pintle ?
ie don't use for trailers ?
Mine only weigh's around 250 KG
Peck
Lever actuated transfer case.
Solid front axle.
Why can't we get the cool stuff!?!?
Nice rig!
miller_au
"the "wrong" side "
ummm good question!?! ive towed plenty of trailers with my patrol. Using a ball and coupling setup. I will change over to a treg hitch setup soon
iStan814
