My Trailer
dwatsonkc
Stilwell, KS
I bought this old trailer 2 months ago for $500. I'll post before pics soon. I love camping and fly fishing. If I use this trailer I plan on getting a At trailer, so i'm doing this on the cheap to see if I like using it. I think it's an old 40's Chevy PU bed??
I have a 9' long Outcast kick boat that sits right on top of the lid/rack that I had built from a local welder. I got the ideas from other members on this forum. I want to thank everyone who has posted pics as I have spend many hours sorting through the old posts looking at pictures.
Things I plan to use the trailer for:
-My camping / Fly fishing trips.
-Haul my Outcast kick boat
-Trips to Home Depot, etc...
List of things I have done:
-Had lid / rack built and installed $525.
-5 cans black spray paint.
-gas can / holder $60
-2 Water Cans $45 from fleabay
-2 mounts for water cans $35 from fleabay
-Axe from wallyworld - $22
-Shovel from Tarjay - $11
-Quick Fist's from fleabay $50 ??
-Tounge box from HF $80
-100 yd Roll of 1.5" Webbing straps $17
-Jack mount $20 from fleabay
-Jack $55 Trtr Supply
-Broom -$10
-Huge bag of SS bolts, screws etc.... $40
-stuff in my garage - FREE
Things I still would like to do:
-have new 3500 lb axle installed that is on order.
-new wheels/tires
-sandblast/repaint
-air shocks??
-lid hinge?? it's really heavy
I'll keep Posting!!
Titanpat57
It's awesome...love it!!
I like all the add-a-goodies on it...can't ever get enough of them as far as I'm concerned...good luck with it!
Pat
gasman
and you want an AT why ?? looks like you have all you need right there. xcept the rtt.. nice job.. (not knocking the AT)
dwatsonkc
Stilwell, KS
I'm kinda a guy that likes to have the best of everything. Winston & Sage fly rods, Leica M cameras. Thats why I want an AT trailer. They are the best.
I have not decided if I want a RTT. My kick boat takes up all the space on top of the trailer. Maybe on my FJ?
I mounted an old Metal Cooler by drilling holes and mounting it to the trailer. I used rubber washers so hopfully it wont leak. If it does not a big deal anyway. The metal cooler was free. It was dented on the side you can't see. The red paint was faded, so a fresh coat of silver cleaned it up. Notice the bottle opener right next to the cooler and mounted on the cooler. Strategic placement!
I have a commercial sewing machine so it's no big deal for me to sew up some webbing. I made the nets and mounted them on the front and sides. Not sure I like them, they also move quite a bit the one time I have been on the highway. The blue bags, one has firewood and the other charcoal. Always stay dry and ready to burn.
dwatsonkc
Stilwell, KS
Mounted the Mag light today. Not sure if they are waterproof and it may get stolen. Most everything else is bolted on or locked.
dwatsonkc
Stilwell, KS
Just bought this last night at Wallyworld for $5. It holds my new Black Diamond latern, paper towels, small trash sack, and room to spare for other things. It comes apart and fits in an included small bag. I think it fits great!
dwatsonkc
Stilwell, KS
$2 Fly rod holder
It's nice to have place to hold your fly rods when you are taking a break. I had this stuff in my garage already. It seems to work great and holds 4-5 rods right under my kick boat. I wouldn't go down the hwy with them but it will work just going across town.
TX_TLC
Nicely done! I just picked up a old Studebaker pickup bed on a home built frame for the basis of my at/camping/utility/work trailer. I love seeing these old beds re-purposed!
dwatsonkc
Stilwell, KS
Here is Pic of what I started with. It has come a long way i think.
dwatsonkc
Stilwell, KS
I Need Advice!
I have been spending most my time on the top part of the trailer. Now I need some help. I have ordered a 3500lb from the local trailer supply. It will arrive in a couple of weeks. I really do don't plan on doing any off roading, just highway driving.
The slipper springs on the trailer are longer than usual trailer springs. Should I keep them or go with traditional trailer springs? The guy at the trailer shop said the current springs could break because they are old and brittle. Before I had the heavy lid put on there was a gap between the welded on spiral spring and the leaf spring. Now because of the weight the trailer has dropped about 1". When I stand on the trailer it does still have quite a bit of bounce.
Should I keep these springs? Should I get traditional trailers springs? Should I just add air shocks to what I have?
Toyotero
Those are quite long slipper springs, and they are rather flat. I don't think that you'd be able to put a spring and shackle without raising the trailer height by at least 2-3 inches. As long as you keep the slipper greased I think it would function equally well.
You are probably planning this for when you change the axle, but if that were my trailer, I'd disassemble the leaves, strip, paint and perhaps grease them. They look solid, but have a lot of surface rust which just creates friction between them.
I like the additional coil spring. I plan to do something similar on a trailer that I'm building by adding a progressive rate coil on top of the leaf springs to soften the ride. like this
- Toyotero.
CharlieGreenT
