dstock
I'm going to be installing dual batteries in my 2010 Jeep JK, they will be mounted side by side in the engine compartment using a Rugged Ridge battery tray. Also, per the directions since I am running a winch, I won't be installing the fuses.
I need the intelligent solenoid and monitor, but wondering if the kit is truly worth it since I don't need much in the way of cable or the fuses.
On the flip side, would love to have everything included, or at least get it all from the same vendor. Done some searching but haven't found any JK specific battery cables for dual battery systems.
Also, curious where on the JK people are mounting the NL solenoid, saw one example of a JK from Mainline where they fabbed up a battery tie down to attach it to, but then read somewhere else where it was bad to mount the NL solenoid horizontal vs vertical? If anyone or any vendors can shed any light on the above it would be greatly appreciated.
TIA
TIA
