kletzenklueffer
Hey all- I bought a truck that has the NL intelligent Solenoid and dual battery controller installed, with two Optima yellow top batteries. The system isn't working well and there are indications that it's the install and not the equipment. The computer board piece of the IS has a crack in the base and a stripped out mounting screw and the underside of the circuit board has signs of electrical arcing. This results in either the solenoid not engaging, or on occasion, constantly clicking to engage, so at the least, the IS needs to be replaced.
My small challenge is that the PO installed the dual battery controller into the console with a surface mount controller. It looks cool, and to use another complete set up for battery management would require either replacing the console to eliminate the hole, or figuring out how to use the controller with a different system and losing it's function as a controller and only using it as a monitor.
OR! I just replace the IS with another one. However, I've read a number of stories of troubleshooting and replacement, although I suspect that the set ups that work get little comment since they do their job as intended.
So my question is for those with the system that have had it for a while- are you pleased with it's reliability and performance? Would you buy it again, knowing what you do?
