National Luna Portable Powerpack 12v DC
osinrider04
Located in Fairfax, VA 22030
Price is $250 obo
I’ll ship if you pay for it
Went to a different setup and no longer need this battery box. I reused the battery controller/monitor ($85 part) that would be needed to have a dual charging system. It’s still available on their website. Below is the manufacturers description:
The National Luna Portable Power Pack is a removeable, compact battery box with built-in split-charge isolator, ideal for modern vehicles that cannot accomodate a second battery in the engine compartment. The design of the Portable Power Pack allows it to be used as a standby power pack for 12-volt appliances.
The Portable Power Pack features fused accessory plugs, a polarised high-power plug and built-in battery monitor with low-battery and over-charge warnings. The built-in plugs can be used for low-power accessories such as refrigerators, pumps, compressors, lights and other 12-volt electronic devices. The high-current input-output can be used for higher power requirements such as invertors or battery chargers. The built-in split-charge isolator is fully automatic and does not require additional hardware in the application vehicle.
Simple installation
Removeable / Portable design
Fully automatic split-charge isolator
Built-in battery monitor and input voltage monitor
Remote battery monitor port (for remote dual battery controller)
Slide-lock lid
Bolt-down / Strap-down design
Electronics isolated from battery compartment
Can accomodate standard automotive battery types
7-metre heavy-duty cable supplied with attached coupler
Fuse-protected plugs and connections
Battery hold-down bracket supplied
In-line fuse supplied
Additional battery terminals and hardware supplied
Additional cables, hardware and monitors available separatelly
