AndrewClarke
Until I recently shorted out my X-Charge split charge system (my fault), it was working perfectly for me. For those unfamiliar with this product, you can see it at http://www.x-eng.co.uk/X-Charge.asp . The specs say it does 180A continuous load and 250A peak, and it is £40.
Now that I've blown it (it's probably repairable but OTOH I forgot it yesterday two hours from where I live), I need to replace it. I'm considering just buying another one, but I think the National Luna split charge system ( http://www.nationalluna.com/intelsol.htm ) would be a drop-in replacement as far as the wiring goes. The National Luna system has the theoretical advantage/disadvantage that it only charges the main battery for the first 5 minutes, while I suppose also making it a more complicated system at the same time. The NL is rated at 85A continuous, 400A peak and costs US$140.
So, X-Charge claims they have a higher continuous load, lower peak load, and lower price. NL has a few more features and is more expensive.
Does anyone see any reason why one is a better choice than the other? I'm also not sure whether I should directly compare manufacturers' specs either, as they source their components from different places.
I don't think I need the NL battery monitor, and since my truck is already wired, I'd skip the kit. BTW this is going in a 200tdi Land Rover 110 with the stock 60A (?) alternator.
In related news, I am bummed that I had to pull out my sweet yellow top Optima main battery yesterday and replace it with a Canadian Tire generic battery. I put in emergency shutoff switches for both batteries and there wasn't room for the Optima, the spiral cell winching battery, and two switches. Overall it's a safer system though, and therefore better.
Thanks,
- Andrew.
Thanks,
- Andrew.
