NDT ok to run tubeless?
From what I am gathering as long as I don't have two piece rims then running NDT's tubeless should be fine correct? I have a David Bradley trailer and it has one piece wheels. What say you?
atavuss
I would ask the maker of the tire you are planning on using. My 1/4 ton Bantam has one piece 16" wheels and I am running tubes in them. The tires do not run hot even when run at highway speeds in 100+ degree days for hours. I am only running 20 to 24 PSI.
Anyone who is interested in this type of tire you should definitely call Coker Tire. Easy to work with and very fast shipping. Now I have to mount them up to make sure the tubeless idea will work.
Houie
