NE PA - Brand FX Custom Built Off Road Trailer
Stoshu
Selling our very unique, comfortable, practical, and durable custom built off road trailer that will go anywhere your 4x4 can traverse. It is based on a Brand FX fiberglass utility body with a custom fabricated 2"x3" tube steel frame that has a heavy wall contiguous 2"x2" center spine from front to back for rigidity and recovery purposes. The trailer was built with the same track width of an 80 series Land Cruiser and designed for serious off road travel with nearly 24" of axle-less ground clearnce. The objective was to provide a weatherproof hard top roof, the comfort of a residential queen mattress, shaded outdoor space, and a hot water shower when you get to camp. It has proven itself with multiple off road trips to CO, UT, NM, AZ, TX, MT, throughout Canada (including the Arctic Ocean), Alaska and the PNW travelling over 35K miles with no issues. It tows and stops beautifully on the highway with zero drama, tracks straight, is light weight, and can be towed by almost any 4x4 vehicle. Clean, clear PA title in my name.
Asking $11,500 OBO. PM me with any questions or additional photos / info.
The following is a list of features and equipment included with the trailer:
  • Timbren axle-less suspension with 4" lift, 3500lb spindles, and 12" nev-r-adjust elecric drum brakes, 6 lug Toyota bolt pattern
  • 35x12.5x17 Ironman All Country M/T tires on American racing 17x8" styled steel wheels
  • EZ connector magnetic 7 pin trailer connector (much stronger trailer plug that won't inadvertently disconnect)
  • Curt tongue jack and rear stabilizer jacks for solid leveling (can also lift trailer to change a tire)
  • CU Off Road Max Coupler 3 axis off road hitch
  • All LED lighting with LED reverse lights
  • 20 pound propane tank and mount (easy to fill or exchange anywhere)
  • 30 gallon on board fresh water tank with pump, hidden fill dish, drain valve, and pump switch
  • Joolca instant-on hot water heater with exterior capture bracket and all water / propane hoses (all stored in a Pelican case)
  • DFG Off Road shower tent with mounts and cover bag
  • 2 - Group 31 SLA batteries for house power
  • 200W inverter with 120v and USB charge ports
  • Fused 12v power distribution block
  • 2 - Exterior SAE charge ports for solar or battery charger
  • Residential queen sized mattress platform
  • 2 - Sirroco gimbal interior fans for cooling and air circulation
  • No-see-um mosquito and bug screens for the two gull wing side doors (great ventilation)
  • EZ Awn K9 Roof rack with Alu-Cab awning mounts
  • Alu-Cab 270 Shadow awning and cover bag with full tent walls, LED R,B,G lighting with remote
  • Large Thule roof top cargo carrier for camp gear or chairs
  • Stainless steel telescoping rear entrance ladder
  • Folding table and two folding camp chairs that fit neatly beneath the bed platform
  • Hike Crew 5.3 gallon portable camp toilet
Defenders-US
