xcmountain80
Yes yes while a random request, I'm trying to sort out some issues on my dads 06 Double cab. A body lift was installed and the ABS wire pulled apart (driver side heading down to the hub with connector located across from the oil filter toward the firewall), the upper portion with connector is there but the lower 2 wires pulled out of the connector. Sounds simple just plug them back in and if in the wrong configuration switch them right? Well that scientific approach did not work. I need a picture of which color goes where. Thank you so much! I had posted this on TTORA but they are to busy doing other things then fulfill such a basic request.
Aaron
Aaron
