Need Alternator Belt Tensioner Bracket for 1995 SR
Toasty
Did your mechanic break it? Rookie mistake and it's a very expensive part, you can work around it by levering the pully then tightening it. The bracket doesn't hold the load, the pully does. That's why guys break them, they crank on the adjuster without loosening the pully.
jeep-N-montero
So to be clear, do you need the bracket itself or the pulley? The bracket does not squeal, but if bent may cause the pulley to do weird things.
Houie
