Need Help fro M416A1 Axle Modders!
Datajockeys
OK, I'm going nuts! A few months ago I got an M416 that needed a little love to get it useable. Turns out that sometime during its life in the Marines and Forest Service, someone swapped out the axle with an M416A1. Of course I had already rebuilt the axle before making this discovery. I also discovered that the new M416 e-brake cable I ordered from Jeep Parts is the wrong one.
There are no M416A1 cables on any of the normal Jeep parts sites. I fear that most get yanked and tossed into a scrap pile during axle swaps. So... I am hoping that someone has a descent M416A1 e-brake cable assy and the mounts that secure the cable casing to the frame underside.
This is the last major component I have to install before the wife puts us to work hauling yard material. yea
Thank you for reading.
Mark Harley
So the 416A1 has surge brakes and a different axle too?
The 416 and 100 trailer parts are not the same?
Datajockeys
Yup, I guess they had to make things interesting. The M416/M100 are more similar. As soon as the surge brake is added, the complexity goes up a couple orders of magnitude.
DeathSquid
I have a really nice ebrake cable, brackets and handle but I need to figure out how to disassemble the connector from the brake drum. I also need one more thing, the exact measurements required to replace this axle with one that has a 6x5.5 stud setup and will fit my FJ Cruiser tires. Everyone on the internet seems to have performed axle swaps but not one has actual measurements. I dont want to use any sort of wheel insert or anything else like that. If I can get this then I can sell you my assembly.
Datajockeys
I read that the M416A1 is a standard axle and the hub can be swapped for one with a proper bolt pattern. The question is offset. I too would like the trailer to have the same tires as my FJ so I will only need to carry a single spare. But the fenders on the trailer will need to be modded, the axle messed with, offset dealt with... I went with OEM Willys Jeep tires and rims and called it good.
DeathSquid
My axle is screwed so it has to go, I have no choice there. Just need to get measurements for spring centers to hub face, spring center to spring center and hub face to hub face, I have everything else. I am sure someone out there has done this based on the threads I've read but not one has an actual measurement anywhere. It's agonizing because I cant measure my axle, its gone.
Datajockeys
Are you wanting stock axle measurements or the measurements folks had custom built? I can help with the stock measurements.
DeathSquid
Stock would be perfect. I can extend it from there as needed. I'm going to run FJ stock steel wheels, thank you!!!!
Datajockeys
OK, the 1st black widow that dropped on me while measuring was about 3/4" but squished up to a nice 1.5" after 3 stomps. Add one beer to tummy...
Axle. spring center to spring center is 39.5". Spring center to hub face is 8.5".
Hope this helps!
iStan814
