I've been trying to find someone who can answer if this can be done without major conversions, I've got the '95 LS 3.0 limited slip and have located a '98 Sport rear locker differential that has the same gear ratio 4.636 w/51 ring gear and 11 spline. How do I know what size axle it is along with what size is mine? Will this bolt up to my existing axle housing? Are the axles the same on both years? Is the locker controlled by a onboard compressor or were they vacuum activated? I've got a lot of questions here I know and would really appreciate expert advise prior to dishing out the $bread for this locker and then it not fitting.
