Need shocks, should I just get a lift kit?
jeep-N-montero
mbialick
Great thank you, and possibly last question, if I were to add lift springs in the future, would I need to replace the front struts to a different length?
Thank you all for the help!
plh
The Bilstein numbers above handle the OME medium springs just fine. I run them on my '05. About 1.5" lift from stock. Do the springs at the same time, cost is ~$170 a pair for springs. It is a lot of work to remove and replace the front shocks. Labor on a very good day is 3 hours for the front pair.
Highly recommended to replace these parts as well in association with the front shocks:
MR448170 Shock Mount - 2
MR455493 Upper Seat - 2
MR353211 Upper Seat Spacer -2
MR448173 Spring Seat - 2
MR374547 Lower Bushing - 2
MR374556 Cup - 2
MR448174 Lower Seat - 2
MF106152 Shock Bolt - 2
MS451115 Washer - 2
MF430124 Nut - 2
MR374546 Upper Bushing -2
MF434105 Strut Mount Nut - 6
mbialick
MR374556 Cup - 2
MS451115 Washer - 2
MF430124 Nut - 2
Do you have a recommended place to order these small parts from?
