Need two caps for scepter fuel cans..???
ejason
I have two of the plastic fuel cans, but i need two caps for them. Does anyone know where i could buy two of them. Thanks.
tantoco
I have four extras from a bulk purchase. They're used, the lip that holds the gasket in place is broken but the gasket stays in pretty well, hasn't affected use. They don't designate if they are "D" or "G", I use them for gas and they seem fine. You can have as many as you want for $10/each plus shipping.
teotwaki
Excelsior!
The lip is broken because rubber diesel gaskets were used with a container full of gasoline.
Ludedude
Yep. Without the proper Viton gasket for gas, this is a common occurrence. I've even seen the caps themselves crack from this although it's less common.
