New Fridge!!
DesertBoater
So my ARB fridge arrived a couple of days ago and since then I've managed to wire a 12 volt socket underneath my rear drivers side jump seat and modify the passenger side seat to bolt to my fridge, now I've got a couple of questions.
What temp do y'all run your fridge's at?
And does ARB manufacture a transit lock-esque mount? The slide-lock won't work because of the way the seats/door work, so I want it mounted in position during use, but need to be able to take it in and out without breaking out my wrenches...any thoughts?
Cheers,
West
cruiseroutfit
Yes, ARB has a strap kit designed to be the 'transit lock' type setup.
Shown here:
In the pic its used as the attachment to their sliding tray setup. Mount the bottom strap ends to your substrate and you've got an easy to dismount and easy to secure setup :cool:
mrchips
I use a couple of web straps around the handles, and then use 2 turnbuckles, and secure it to anchoring points in the Jeep. It stays in place and so far works great.
I set the temp @ 34F, and it will vary from top to bottom. Now that winter is here probably bump it up a couple degrees, as the low will be 27F when I go out this week-end to the desert.
xander69
