New Land Rover Friends
MrWesson
Jeep guy who has shopped for Disco's on 3 separate occasions.
Always got a kick at how common those amigo's are and how difficult they are to fix.
Even bought a cheap scan tool for under $100 that scans and clears abs codes.
The Rover Shop
They aren't expensive to fix.. There is a wiring mod that fixes it very cheap.. The problem is the contact pins inside on the shuttle valve lose their tension and you get a constant code for shuttle valve failure..historical... You run those wires outside throught the shuttle valve and straight into the harness and problem resolved.. We install a new shuttle valve at the same time.. If it's coming up with a code for wheel speed sensor just replace that... New one comes with a long wire that you are supposed to run alllll the way back to the computor..you can just splice it in after the 2 pin connector..just solder it... They wanted to get rid of the poor connection at the connector terminal..
Kgh
Let’s go already!
Shayne nailed it. Not just shuttle valves. They have departed for now.
Funny how with Disco turned off and parked they "chirp" at me, from ABS controller. At first I thought garage fridge was wonky!
Viva la Disco!
lkretvix
