New member planning a build
Dan_2k_uk
Hi.
I'm in the UK and fed up with frequently putting a tent up and down and having no space left in my truck once loaded up so I'm looking at the feasibility of a small semi-offroad camper trailer.
My biggest problem is going to be weight and size as my truck is a Suzuki Samurai so the whole thing needs to be less than 1700mm wide to track behind the truck. Also from speaking to a few others who tow conventional trailer tents with their Samurais I've been advised a good target weight would be 500kg.
I don't really need to carry water as its not actually for expedition so to speak and if I did need water I will just carry it in the truck.
I would like some basic electricity. Battery, solar panel, led lights, maybe a small sound system.
I would plan to build it from scratch so I can use matching Suzuki components. So a rigid axle with Samurai stub axles and using Samurai leaf springs too.
What kind of construction should I look at to achieve this size and weight if its even possible? I was thinking 20-25mm box section steel with a 2-3mm wall thickness?
Obviously I will need some heavier steel for the the chassis bit so I was thinking that if I aim for the floor to be a bit more of a monocoque design rather than making a trailer and bolting the floor to it it will save some weight.
I'm thinking I will clad the outside with thin aluminium and thin ply on the inside with dense foam insulation between?
Do you guys think I will achieve this weight with this style of design or am I dreaming?
That's probably enough questions for now although I have many more.
This is the kind of shape I was thinking of.
Thanks in advance.
Dan.
Here's a photo of my truck too just for fun.
Dan_2k_uk
Also. I have looked through some of the builds on here but if any really stand out as being good reference for this type of build then info on which to look at would be great.
Thanks.
