New OME 762 Springs - One HIGH Corner
t42beal13t
I just wrapped up installing new OME 751 and 762 springs. Three corners look great but the rear left corner, with spring marked 762A, is sitting a good two inches higher than the others. I triple checked that the spring was seated properly and I can't find any reason for this corner to be sitting so high. Any insight?
luckyjoe
Two options, swap rear springs left & right, OR, swap front springs left & right.
Did you take measurements with your previous springs installed? Did you have a low or high corner?
t42beal13t
I didn't have a high corner before running RTE 3" springs so I don't see how swapping springs around would help.
I didn't measure but visually you can tell it went from being level in the back to a few inches higher in the left rear after the new springs went in.
flipstick
