New OME Supsension Install on Monday
fangars
Having Sierra Expeditions install new OME suspension, springs, torsion bars, and shocks, on my 1991 Montero LS, LWB.
What other suspension items should I replace or at least inspect?
off-roader
Anti sway bar bushings (with age they rot and start squeaking), tie rod ends, CV joint covers, steering system tightness, wheel bearing wear, etc.
These are all things a typical mechanic can inspect.
fangars
Is there a particular brand I should be looking for or looking out for as far as quality goes or are all the parts out there fairly the same?
off-roader
For the parts I mentioned the Mitsubishi OEM parts are very high quality.
For the upgrades you mentioned, OME is certainly decent quality although for shocks, I prefer KYB Gas Adjusts. They're cheaper than OME and work just as well.
For a coil spring upgrade, I also prefer the Gen II coil springs because they're progressive rate springs which ride far better than constant rate springs while also and providing an extra 1-2" of lift on a Gen I. They're also inexpensive at a parts yard.
fangars
I probably should have asked about the coil springs before I ordered the OME stuff, which is all paid for and fresh off the boat from Australia.
Will be posting pics soon.
