New Product - Vector OffRoad MP Table
Vector OffRoad
Supporting Sponsor
FREE SHIPPING THROUGH 11/30 IN CON US.
MP Table (Multi-Purpose Table) $159.99 In stock and shipping immediately.
The Vector Off-Road MP Table (Multi-Purpose Table) installs to any vertical surface with a minimum surface area of “29-1/4” x 11-1/16”. When stored in the closed position the table only protrudes a maximum of 1.25” from the mounting surface. The working area of the table is 11" Deep x 27.5" wide.
Designed to provide maximum usability in a light weight and slim package, the MP Table incorporates ¼” holes and slots to allow the use of QuickFist™ Clamps and Molle Straps for mounting trail gear, tools and pouches to the table. There are also convenient holes along the outer rim of the table for hanging your cooking tools if you are using the MP Table as the base of your kitchen. To quickly deploy the table, remove the two knobs on either side of the table, fold the table down, and place the knobs back on the studs.
The MP Table is laser cut and manufactured in the USA from aerospace alloy aluminum. All of the mounting hardware is high quality stainless steel and is easily field serviced. Even the cables are 100% stainless steel and polymer top coated to further prevent rust and fraying. The MP Table will provide you with many years of trouble free service.
Morticon
you have a picture here of a little girl sitting on the taple. do you have a load capacity for the table?
Bigjerm
SE Expedition Society
I like it but I got the rugged ridge tailgate stop attached to my gate and I don't think the 2 will work together...
Vector OffRoad
Supporting Sponsor
We evenly loaded a table with well over 100 lbs with no problem. Slight deflection at 150 lbs, so our official rating on the tabe is 75 lbs. Thanks for the interest.
JPK
I have a Best Top multi box or whatever its called installed. It has sheet steel sides. I'll look when I get home from work, but I think I would have to cut the steel to move the speaker.
Perhaps you all make or could make a version which would fit with the sub-woofer?
JPK
keithro
Does the tailgate stop sit at or above the level of the plastic cover that covers the tailgate wiring?
Post a picture of your tailgate and stop and we'll see if they'll work together with the table.
Bigjerm
I just noticed its a JK gate in the picture and I drive an LJ. Do you make one for the pre 2007 model?
Vector OffRoad
Supporting Sponsor
We'll have a look at the next TJ we have around and let you know. Until then you could take some measurements and check the size. The table will mount to any flat surface....would be great on the side of a trailer!
Vector OffRoad
Supporting Sponsor
Here are some pics of our MP table loaded on the underside with gear using QuickFists.
Vector OffRoad
Supporting Sponsor
We are running a Super Bowl sale on the MP Tables, now through Sunday, $30 off + free conus ground shipping!
We are also running a marketing promotion that can get you an additional $40 rebate on each table. To qualify for the rebate you must install the table on an application that hasn't been previously seen and send us high quality pictures of the application. Currently the only application that doesn't apply is a rear tailgate JK. For example if you buy a MP table and mount it on the rear tailgate of your land cruiser or on the side of your offroad trailer and send us a picture you would qualify.
http://www.vectoroffroad.com/product...4unerg0stjrms0
Clemtiger84
