new shoes for the jk
LUISJG
just droped some 33x11.5 on the stock jk,,, 5 inch backspace on 16 in wheels.
I was impressed with how much did the tires lifted the jeep..
bad picture cause its dark ...
MtnMan
Nice set-up, I have been running 285-75-16s on Cragar Sft 8s, but have had clearance issues with the front brake shoes. The solution was to put in 1/4 inch spacers, which in turn caused a nasty steering wobble at around 45 mph, and the lug nuts loosening every 100 miles or so. Final solution was to change rims to a set of AEV cast wheels. Drives like a dream now. I love the look of the black steelies. Hopefully you will not have similar issues.
Brad
kcowyo
ExPo Original
LUISJG said:
just droped some 33x11.5 on the stock jk,,, 5 inch backspace on 16 in wheels....
What tire is made in a 33x11.50x16? They look like MTR's but can't tell for sure....?
LUISJG
yes they are mtrs, they sell it like 285 75 16 ,, and meassure 32.8 x 11.5
idont see how to have brake shoe problem,, hope not,,never heard this before.
LUISJG
Brad
I see what you mean now,,yeah the brake shoe bracket is preety much in contact with the wheel,,,
2 chioces,,,grind on the bracket just a bit or replace wheels,,with another backspace,,good thing I can return this here ,,bad thing is I like the backspace it has....
thanks for telling me
LUISJG
update.
well went back and looked again ,,i was able to pass a piece of paper between the bracket and wheel so they are not touching but preety close
,,they realy look like the are but they dont,,
2500Adventures
here's a local JK 2-dr running 37s with a 4" lift i believe, i'll have to fuind out for sure...
And here is a local 4-dr with a modest 2" lift and some black steelies, looks great with that burgandy/plum color I think
The Swiss
:clapsmile Looks great, Luis! Amazing what a difference bigger shoes make in the entire apparence of the vehicle!
LexusAllTerrain
Congratulations Luis you made the right desition on the tire size, I have done some research and found the 33" to be the biggest tire size you can install, before you have issues or concerns with the axles.:wavey:
