TeraFlex JK Wrangler Performance Big Rotor Kit
TeraFlex Inc., manufacturer of TeraFlex suspensions, body protection equipment, low range gearing and HD axles, introduces the newest performance component for the JK Wrangler.
The TeraFlex JK Performance Big Rotor Kit is the perfect upgrade for JK Wrangler owners requiring increased braking performance for 33-35” tires.
This kit allows the factory brake caliper and brake pads to be retained, while increasing the rotor diameter from 11.9” to 13.3”. The increased clamping distance from the rotor center results in greater braking leverage to allow stopping distance to be decreased substantially (larger rotor diameter = greater stopping power). The simple bolt-on installation upgrade requires absolutely no brake line modification or brake bleeding, and can be installed with basic hand tools.
Product Features & Benefits:
• Brake caliper relocating anchor bracket
• 13.3” slotted rotor for superior stopping performance
• Mill-balanced vented rotors for maximum heat dissipation
• Improved braking performance over factory brake system
• Retain factory brake caliper & pads
• No brake bleeding or brake line modification required
• 100% bolt-on upgrade for easy installation
• A minimum of a 17” wheel must be used with this kit
TeraFlex JK Performance Rotor Kit
Part# 4303480
MSRP $289.99
Includes:
• 13.3” mill-balanced performance vented rotors (qty 2)
• Brake caliper relocating anchor brackets (qty 2)
TeraFlex JK Performance Slotted Big Rotor Kit
Part# 4303490
MSRP $311.99
Includes:
• 13.3” mill-balanced performance vented & slotted rotors (L & R)
TeraFlex products are available direct, or through authorized TeraFlex Dealers. For a complete list of Dealers in your area, or to purchase direct, contact TeraFlex at 801-288-2585 or visit them on the web, www.teraflex.biz.
