new to me dodge dakota
hugh
I just purchased a 2000 quad cab Dakota 4wd. 140,000 km,s. It came with a safety inspection, mandatory in our province and I bought it from one of those smaller used car lots. Sold my 98 XJ I had been turning into an expedition type vehicle. Well I took it to Costco and had a new set set of 31-10.5 15 inch BFG,s installed. Anyway, I took it to a garage I trust and sure enough the front rotors were almost worn out, 1 ball joint was shot along with the steering rack. I got slightly burned .The plan is to turn the Dodge into my expedition vehicle. I went to far on the XJ and will keep the Dodge mostly stock. First i bought a used truck cap for it and painted it with Duraliner. i also bought and installed a receiver hitch to pull my small home made camper on 31 - 10.50,s. It got a 7 pin plug and I will hook it up to run the electric brakes on the trailer and charge the trailer battery. I also have a 2nd sealed battery which will be mounted in the front corner of the box and hooked to an electronic dual battery system which isolates the 2 batteries and also allows you to jump start yourself if needed. A Viar compressor will also be installed in the back. Here,s a picture of the start.
This was taken just after buying the truck at a blues music festival the wife and I went to. The Dodge runs the 4.7 V8. You can hardly tell its towing the trailer, I made it to tow behind the XJ and it is almost exactly the same width as the Dakota cab with the outside wheels being very close to the width of the truck.
Hokie
Looks good! I just bought a 2002 Dakota quad cab with the 5.9. Thankfully, everything on the front end seems to be in good shape. So far, the wife and I have done a few small road trips and we are very happy with it. I think I am going to keep my M416 trailer that I originally bought to go behind my CJ and build it up to a utility/camping trailer as the width is very similar.
What kind of cap did you go with and why? I am searching Craigslist but not a lot out there for quad cab dakotas so I am thinking I may have to go new and just overwhelmed with the options and styles.
hugh
I put an ad in our local Kijiji and bought a cap in good condition from a local guy from a 2005 quad cab. Not sure but since it was the same blue as the guy,s truck it may have come from Dodge. Anyway, it,s the same profile as the cab. I bought it since I have a canoe so I installed a rack on it, plus the winters here are pretty harsh and it will keep snow from piling up in the box. Turns out the steering rack was leaking so I picked one up at Napa and will be installing it today, when done I will take a picture of the truck with the cap on it. Then i start installing my upgrades.
flipstick
