New to me skamper
camrog91
Recently got a skamper 080s from a buddy of mine when he upgraded. Will be in my 96 k3500 mainly when I go rock crawling in my Toyota. Not bad roof seems to need to be resealed as there is a few water spots on the ceiling. Everything seems to work. Looking to put a battery in it but doesn’t seem like it had one before. Can anyone point me in a direction of a good write up on adding a battery inside camper? Would like it to charge off truck. Haven’t plugged in the 7 pin plug coming from camper yet to test anything. Will probably post on here as I upgrade. Cheers!!
kerry
I put EternaBond tape over my roof seams--8" wide as I recall. I also put a 2" strip over the seam between the sides of the roof and the aluminum bottom trim since water runs down inside between the roof aluminum and the trim and then gets wicked up into the wood on the sides of the roof.
camrog91
. Was planning on using this. A good friend works for a commercial roofing company and has used this a bunch of times before. I got a full 5 gallons and don’t expect to use much at all. Weather isn’t in my favor to get it done right now. So it sits with a tarp until nicer weather.
project13support
