Saharicon
Hey guys. I just purchased Jeff Lawrence's cargo trailer build.
Jeff did an amazing job on this trailer. It was exactly what I had been looking for. I will be starting another thread about the trailers new adventures as I assured Jeff's wife and son it would go on, as Jeff would of wanted.
The wife and I purchased our Tacoma in August last year with for the purpose of overland travel. I should note that it does have the tow package.
Fortunately, the misses loves traveling all over in the middle of nowhere. We also have 2 siberian huskies and would like to be able to stay out for weeks at a time. The trailer seemed perfect for our needs.
I have never owned a trailer so I have a few questions if you guys wouldn't mind...
First off, I picked the trailer up and had about a two and half hour drive from LA back up 15/395 to the DV area. Never hauling a trailer I was pretty nervous, but it went great! Trailer towed awesome and a couple times on those long boring stretches across 395 I almost forgot we had a trailer.
I read a lot about what gear to tow in before I picked it up and got mixed reports on the forums. I stayed in 4th most of the time. Is this the proper gear I should be in when towing with the Tacoma?
Also, I am not sure what the exact tongue wait is. I believe the trailer weight about 2100lbs overall. What is the best way to find out the tongue weight? Truck scale under the front jack?
The Tacoma towed the trailer just fine, but I noticed that the rear end did sag some and the rear was a little bouncy over some bumps. I had planned on doing a full 3" lift, but with the trailer purchase this will have to wait a little bit longer. What would be the best thing to do in the rear suspension for hauling the trailer, but also daily driving without the trailer?
Lastly, Jeff put airbags on the trailer. I have zero experience with airbags, but I read in the build that you could lower and raise the trailer with this. I did find where the air lines and everything ran with a typical tire stem. What are the proper PSIs I should be checking especially for during towing? Also, I was going to get a CO2 tank for airing up tires on the trail. Can the airbags use CO2 as well?
I think that is the majority of the questions I have. If you guys think I should know anything else about hauling a trailer, especially off road, please let me know. I am getting a break controller first thing.
Thanks in advance!
Thanks in advance!
