New traction mat: Max Trax
OutbacKamper
Supporting Sponsor
I spotted this new product at the Brisbane 4x4 show. According to the company they may be available in North America soon. They are expensive, but seem to be a very well thought out product. I trid to talk then into providing me with a set for "testing" but no luck. Maybe Scott can talk them into providing EW with a set for testing?
http://www.maxtrax.com.au/
"Maxtrax Action" has 5 movies showing the product in action
Cheers
Mark
do they work for bridging?
IMO, at that price it doesn't seem worth it unless they do...
Nope
They are rather expensive aren't they. I can understand that a lot of R&D and testing was required, but the actual manufacturing cost would be minimal. Perhaps prices will come down in the future.
I can tell you that the Australian SAS are testing them and the RAAF (Royal Aust. Air Force) are looking into using them on there Caribou aircraft. The caribou is designed for short takeoff and landings on dirt strips. My cousin flies a RAAF Caribou and has gotten it bogged in mud on dirt strips while taxi-ing in Papaua New Guinea several times. The light weight would be a plus for aircraft use and the lack of use as bridging would not be an issue.
Cheers
Mark
Maxtrax revived...
Replying to an old tread. I've recently watched the Great Sand Adventure - Faser Island by they crew from Australian 4WD Action (formerly Australian 4WD Monthly) and they used a set of MaxTrax that was bolted to Milo to help get some tourist unstuck from the sand. Seems like a cool product, but I have not yet laid my hands on them.
Cheers,
P
I was out with Bill Burke over the Holidays and he entioned them very, very favorably. I got an email from him a few days ago in which he mentions them:
"Recently I was sent a set of MAXTRAX to try out. Check the site <http://www.maxtrax.com.au> www.maxtrax.com.au for a better look! You all know I have been using carpet strips because I couldn’t stand having to carry along those heavy metal “sand ladders” or any other type bridging materials. I have used all sorts of devices to help me get unstuck from deep sand, mud and snow. The MAXTRAX really are lightweight, strong and very easy to use. They are designed to be able help dig the offending soil away from the tires by holding the handles and using the MAXTRAX as a large scoop.
Once the soil is moved away from the tires, the MAXTRAX is jammed just under the tires (I use 4 but 2 will work). The MAXTRAX have an aggressive surface and the ends are “ramped” to facilitate the tire to grip which allows the vehicle to pull it self onto the MAXTRAX. When the tires start climbing up onto the MAXTRAX it also helps raise the frame up and get out of the high center situation as well as getting out of the ruts that were dug by the tires.
These real easy-to-use and carry devices are now a permanent part of my vehicle equipment. Brad from MAXTRAX is working with a few special companies to carry the MAXTRAX in the USA. Look for them soon, but in the meantime you can contact Brad McCarthy at MAXTRAX to find out where and when you can get them. It’s been a while since I’ve gotten excited about new equipment, but these things have already proven themselves for me with my training sessions in the snow and sand. If you are using those old school slippery sand ladders you should seriously consider looking into getting a set of MAXTRAX.
You all will probably be reading about them soon enough in some magazine or other. I thought I would pass it on to you with first-hand knowledge."
I plan on getting a pair or two when they become available stateside.
If a person was to air down your tires sufficiently, and you had a winch or a buddy with you, why would you need these. I was told to never venture out unless you have a buddy with you, that does make sense to me.
I'm not going to constrain our "venturing out" to only when there are others to go with. There are times, due to our work schedues, when we go out by ourselves. And I am pretty well equiped with winch, 50ft winchline extention, tree savers, 6 shackles, 2 snatch blocks, 3/8x20 ft chain, HiLift, Pull Pal, shovel etc and the knowledge to use them. These are just one more tool, like sandmats.
From what I have read on their website they are light and they stack.
I'm excited about them. I know that there is a US vendor testing them out now. I'm sure he will fess up soon, but I call dibs on the first set.
-Ben
Has anyone tried these?
http://www.okoffroad.com/stuff-waffleboards.htm
I bought a set of sand tracs from a guy who was making them for RV's. he was located in AZ but I can't remember his site. They looked very well make .
I wonder about these "waffle boards". They look like what we use for decking on our pump trucks. It's called "molded fiberglass grating". We buy it by the 4x8 sheet or 4x12 sheet. If it's the same stuff it looks like the aftermarket is grossly over pricing these as "making" them seems to involve a simple crosscut of a std industrial product.
These are available at Mcmaster-Carr at www.mcmaster.com on page 2066. A 4'x8" sheet 1.5" thick with 1.5" square grates is 656.00 and a 4'x12' sheet is 929.00. So you could get nine 4ft x 15" out of the 12 ft sheet at 103.00 per or six 4ft x 15" out of a 4x8 sheet for 109 per. So a pair would be 206.00 or 218.00. Sounds like a great thing for people in reasonable geographic area to go in on and save some bucks. Obviously going with the 12 ft length would involve buying two sheets to get a full set of pairs. Or make them just narrow enough to get 10 out off 12 ft.
Various suppliers offer this in thicker and thinner versions and, in addition to the green above, gray, yellow and orange. 5ft widths are available too.
Jlbeats
