mep1811
Gentleman Adventurer
I did a little work on my M416. First up was a dual pneumatic tire tongue wheel. I'm hoping for better rolling on a rough surface. I took the tongue to my local welder and he widened the bracket.
Second up I built up a cooler slider. My 45qt Yeti is heavy when loaded and a PIA to drag out to get into. I bought 100lb sliders from Lowes and some aluminium angle iron. I went with 4 X 3. A plywood board is the base for the slide which I painted with black Flexseal.
It took a little adjusting to get the slider frame square and level but works just fine.
Next up is getting the tongue fixed. The extended lunette tongue I had, bent during my last trip. I am going to have it lengthened a bit so I can open my tire carrier without unhitching and replaced with some square tube.
