Newbie Run
Out2PLAY
If you are in So Cal area have a JK, JK-forum is doing a newbie run at last chance canyon on March 19th
Here what you can learn
1. Airing down your tires
2. Disconnecting your sway bar links
3. How to use your transfer case
4. How to use your lockers (if applicable)
5. How to pick a good line/Tire placement
6. Throttle control
7. General off-roading safety, tips and tricks
Minimum Requirements
While the trail we will be running is easy enough for any stock JK to make it through, we will be requiring that all participants have at minimum front and rear tow points. While rocker guards and a CB is not manditory for this run, it is HIGHLY recommended.
Clemtiger84
