Nissan Xterra Rear Radflo Emulsion 2.0 shocks
Strizzo
I have a set of rear radlflo emulsion shocks off my 2010 Xterra. Took them off because I went to a taller/stiffer setup and these are not quite long enough. They should work fine for an xterra with a 1-2" AAL or shackle lift or a frontier with 0-1" of lift. These were great with the stock leafs and a 2-leaf aal setup, which would stuff the axle to stops when completely flexed out. These have been on the truck for just over two years but other than the little bit of dirt that doesn't seem to want to come off, and the small rock rash on the lower mounts, these look and work as new. there are no leaks or seepage from the seals, and the lower mount bearings still move freely with no play or slop.
the shocks:
Rock rash on lower mount:
rock chips on other lower mount:
looking for 275 shipped from houston, tx to the lower 48.
