Nitro Gear Long Travel Tundra, Supercharged on 37s
nitro-gear
Supporting Sponsor - Differential & Axle Parts
The Long Travel Tundra up for sale, if you are interested please email Carl@JustDifferentials.com for more info. Please do not PM us on the forum! It is priced at $47,500.
Possible partial trade for
-Toyota Tacoma, Land Cruiser, 4Runner
-2014+ Subaru outback, Toyota Highlander or other Japanese car based AWD SUV.
Full spec list:
2007 Toyota Tundra Crewmax 4x4 123k miles on truck
-10,000 miles on New 5.7 Toyota 3urfe Motor
-TRD Supercharger, Doug Thorley longtube headers, Magnaflow / stainless exhaust.
-ClassicSoftTrim Leather & heated seats installed on Sr5 30/20/30 bench Seats 6 adults!
-Kenwood navigation deck, remote start, backup camera.
-Rebuilt diffs with Nitro Gear 4.88 Ring & Pinions, Auburn Pro LSD Rear Posi
-Set of 5 Nitto Trail Grappler 37/12.50R18 mounted on OEM Toyota TRD Pro Tundra wheels.
-Body style Update to 2015 TRD Pro with OEM Toyota hood, grille, headlights, taillights, tailgate, Fresh Radiant Red Paint on the whole truck, all professionally done.
-Front Suspension: Total Chaos Long travel with heim uppers for more adjustability, Icon 2.5" remote res coilover, secondary Icon Bypass shocks, timbren bumpstops, Extended axles to retain 4wd
-Rear suspension: Total Chaos spring under kit, Icon bypass shocks & hydraulic bumpstops, Atlas Springs, Total Chaos shackles, custom heavy duty long travel airbag kit, Anti-rock Torsion swaybar, reinforced, boxed frame, additional crossemembers, custom bumper built onto OEM Tow hitch receiver to retain towing capability
-SDHQ Front bumper, Fenders, and bedsides
-Warn XP9000 with synthetic line, factor 55 pro link
-IPF Intensity lights x3
-Rigid D2 Amber fog lights
-Oddessey battery, Amp Research Powersteps
-Fresh Line-x'd bed
-All maintenance done regularly, new TRD brake pads & Crossdrilled / slotted rotors
-Toyota OEM Bed divider, tie downs, rail system
-Trifold hard folding bed cover allows bed to be securely locked.
For more info and pics, check out this link: https://nitrogearaxle.wordpress.com/2016/08/25/nitro-supercharged-trd-pro-tundra/
fireball
Most important spec:
Crew Max with a 6.5' bed!!! The configuration Toyota should offer from the factory!
nitro-gear
The frame was stretched to accommodate the 6.5' bed on the crewmax. Since it was cut and modified they started the project with a truck that had been rear-ended, rather than cutting up a perfectly fine one. The work was done by Precision Bodylines in SLC who are well known for the hundreds of longbed Megacab dodge conversions they've done.
iStan814
