Nitro Gear - Our Chromoly ROCKS!
nitro-gear
Supporting Sponsor - Differential & Axle Parts
Chromoly - A mix of Chromium and Molybdenum, is designed to offer a significant increase in strength over the OEM axles. This is a great addition if you've fitted larger tires, added accessories and use your vehicle for off-roading. These HD Nitro axles boast high-strength chromoly material featuring state of the art machining, heat-treating and polishing processes for uniformity and increased strength. Fully compatible with factory or aftermarket carriers and lockers.
Shop for your vehicle HERE:
http://www.nitro-gear.com/Nitro-Axles-s/114.htm
Jimbo12
I'm a fan of Nitro products. I just purchased some Nitro 4.30 gears, had them installed, and it turns these 37's like nothing.
dterrell
