I know I've posted about this before but I decided to start a new thread because it's a bit different than the others. I've got an NMO with coax attached sitting on the work bench ready to go on the 4Runner for CB duty (2m NMO is already installed). I'm going to drill a hole, no mount, and had a question before I do the deed.
Question is if I'm on the right track. I plan on getting a 27mhz Larson with NMO base. One issue I have with this antenna is that it's close to 4 feet long. It isn't a huge problem but here and there it will be an issue. I have no problem with unscrewing it for parking garages, trees, brush etc. I want the NMO because I can install it clean and when I'm not using the CB I can cover the threads and go about my business. Another reason for the NMO is flexibility, just like with my 2m setup.
I found this adapter:
http://www.walcottcb.com/opek-nmo6-nmo-to-38-24-thread-adapter-p-1231.html
Before I drill a hole I want to make sure I have usable flexibility. Like I said the Larsen will be on duty when I use it but something smaller will be nice. I was thinking this adapter and then a flexible (not fiberglass and NO spring) whip will be nice. Something like this (just a quick google search):
http://www.solidsignal.com/pview.as...nable-Stainless-Steel-CB-Antenna-Whip-(A-110)
So again with the question. Is this a solid route to take? It's the 3/4" hole in the roof that is causing the doubt and question. I know a short antenna will have decreased range and other down sides but just wanted to bounce it off someone and I didn't want to have the 4 footer as the only option.
TIA,
Mike
TIA,
Mike
