Noise from Rear Brake on my '99
All-Terrain
No Road Required
When you push on the brake pedal, the right rear brake on my '99 Montero makes a squeaking/groaning/dragging noise.
When you take your foot off the pedal, it goes away.
Any thoughts?
jeep-N-montero
Any thoughts?
My thoughts are that maybe you should pull the wheel off and take a look for yourself, 99% certain that either the pad wear indicator is contacting the rotor(could also be a bent rotor) or the caliper is starting to stick, asking for a bunch of opinions will only get you so far until you take a look and then ask for ways to fix it. Brakes are very simple to work on.
