Nth Shock Shifter and OME Shock bushing issue.
Beowulf
Did OME change their shock lately. I just got a call from AEV saying that the OME shocks would not fit the Nth Shock Shifters. So they are not installing them. What has changed?
Has anyone installed new OME Shocks on an Nth SS? Any pics?
goodtimes
Expedition Poseur
I'm not sure, but I'd bet OME did the same thing Rancho did with their RSX's....the bushings are these stupid-soft things that are molded around the bar-pin...you can't press the bar-pin out and re-use the bushing. I simply replaced the bushing with some off the shelf bushings when I installed the shock shifters....kind of a pain, but if I can do it in my garage with a vice and a hammer...I'm sure AEV could figure it out......
cshontz
Supporting Sponsor
Just speculating, but could it possibly be a clearance issue with the metal shroud on the OME canister? Most other aftermarket light truck shocks that I know of have an exposed post or a soft boot.
Beowulf
No, I have just found out it is the pin is flanged and built in the eye bushing.
There should not be a clearence issue since people had been using the Nth SS and OME before.
Where did you get the generic bushings?
goodtimes
Expedition Poseur
To be honest, I don't recall. I *think* they were 5/8"...I seem to recall installing a steel sleeve inside the bushing and using a 1/2" bolt for the pin....
Beowulf
Did you already have the sleeve, or were you able to buy one of them also?
I am tempted to call OME and see if they sell replacement bushing and sleeves.
